Checking if the application is running before uninstall
icaronz
Post by icaronz »
I'm trying to check if my application is running before I uninstall it so I can pop up a message asking the user to close; but I can't find any information about how to do it.
Any help is appreciate.
Re: Checking if the application is running before uninstall
you could use the "Check Process" command and then if the named process is running, use "Terminate Process" to stop it.
