Program Files direcory localisation
Ton_B
Postby Ton_B » Tue Mar 11, 2014 9:33 am
I've created a generic setup which can be started with a command line.
This command line contacins the setup location lik "Program files"
Inside my script i detect if the current OS is 32 or 64 bits and alter the location to "Program Files(x86)" if the system is 64 bits.
But because in some countries this path do not have "program files" I would like to get the default "program files" directory name oth the current county.
See:
http://en.wikipedia.org/wiki/Program_Files
in .NET you can retreive it with this code: http://stackoverflow.com/questions/194157/c-sharp-how-to-get-program-files-x86-on-windows-vista-64-bit
in vb6 you can make an api call like this : http://www.developerfusion.com/code/251/special-folder-paths/
The question is, does IA has a similar function? or do i have to make a api call?
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Re: Program Files direcory localisation
Postby FrancescoT » Tue Mar 11, 2014 1:23 pm
Dear Ton,
The IA command "Get Folder Location" does exactly when used to acquire the "System->Program Files".
If you need to dected the target Program Files directory based on the target OS platform, just call the "Get Folder Location" after a Set x64 statement.
Example;
Set Variable ISWIN64 to FALSE
Get System Setting Windows in 64 bit Mode into ISWIN64
if Variable ISWIN64 Equals TRUE
  Comment: SWITCH TO NATIVE 64 BIT MODE
Get Folder Location System->Program Files Directory into PROGRAMFILES
  Comment: SWITCH BACK TO NATIVE 32 BIT MODE ... IF YOU ARE INSTALLING A NATIVE 32 BIT APP!
Ton_B
Postby Ton_B » Thu Mar 13, 2014 1:15 am
Hello Francesco.
Yhank you very much!
Your sample code is exactly what I need, including the "swich back to 32 bit" !
Ton Blokhuizen
Tooling Engineer
Postby FrancescoT » Thu Mar 13, 2014 9:16 am
:D
Users browsing this forum: No registered users and 102 guests
