PTShellList
markoh3
PTShellList
Postby markoh3 » Thu Mar 13, 2014 9:58 am
If I use a PTShellList how could I enable the Next button after a user selects a file?
Thanks in advance.
Re: PTShellList
Postby FrancescoT » Thu Mar 13, 2014 12:24 pm
Unfortunately, you can't currently.
Alternatively, from the MSI script code you can check if a file has been selected and if it's not, you can force the dialog that includes the "Shell List" control to be displayed again ... until a valid selection is made.
For example, you could use an approach as follow;
Set Variable MYFILE to //This variable must be associated to the "SHELL-LIST" control  ... to hold the selected value.
while Variable MYFILE Equals  loop //While  MYFILE is Empty
 Display Dialog: MyDialog, wait for dialog to return (modal) // The dialog that includes the "SHELL-LIST" control
 if Variable WIZARD Equals CANCEL
   GoTo Label: xxxxx //Go-to a previous dialog
 if Variable MYFILE Equals
   MessageBox: Error, You must select a file!
wend
markoh3
Re: PTShellList
Postby markoh3 » Fri Mar 14, 2014 2:10 am
Hi Francesco,
Thank you for your quick reply.
This works for me! :D
Re: PTShellList
Postby FrancescoT » Fri Mar 14, 2014 9:08 am
:D
Users browsing this forum: No registered users and 89 guests
