Uninstall problem
somnetics
Uninstall problem
Post by somnetics »
I have an InstallAware project that installs product A.
Starting with that project I made a new project, by copying the first project to a new folder, and change everything I could find to change, so that it will it to inatall product B.
Now when I run the Install executable to install product A it UNINSTALLS product B.
When I run the install executable to install product B it UNINSTALLS product A.
Where in the project is it setup what to uninstall?
Re: Uninstall problem
Did you used a new PRODUCTCODE and a new UPGRADECODE with your new project?
Once you changed both, I am sure you'll solve your problem.
