Is it possible to find the merge modules for:
MS SQL Express 2014 x86
MS SQL Express 2014 x64
Best
Kurt
MS SQL 2014 Express for IA15?
Re: MS SQL 2014 Express for IA15?
Dear Kurt,
those runtimes are included in IA 18 ... anyway, if you specifically need them as merge modules format, you should verify their availability from Microsoft directly ( ... honestly, I don't think they supply those runtimes as merge modules ) .
Can i ask..
What is merge modules?
regards,
Akmal
regards,
Akmal
Dear Akmal,
please refer to the following Microsoft documentation.
http://msdn.microsoft.com/en-us/library ... s.85).aspx
