Our software depends on Kodak imaging components, like IMGTHUMB.OCX.
On most computers the setup runs just fine, but just one client it fails to register the components.
Searching the internet i found this topic : http://kakopa.com/imaging/ (scool all the way down, to window 7 section)
It seems that on this machine something is wrong with the rundll32.exe, because I had to run "rundll32.exe setupapi,InstallHinfSection DefaultInstall 132 IMAGEVUE.INF"
Is there a way I can embed this functionallity (see attachment) inside my setup ?
Imaging for Windows fails
- scanner-win7.zip
- (1.13 MiB) Downloaded 435 times
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Tooling Engineer
Re: Imaging for Windows fails
Dear Ton,
Just use the same identical approach I described here; http://www.installaware.com/forum/viewtopic.php?f=2&t=9962
In your case you need to execute the "install_win7.bat" file, instead of the VBScript file illustrated with the above example.
Users browsing this forum: No registered users and 176 guests
