I have an XML file with a simple structure:
<xml>
<test>
<user>John</user>
<id>1</id>
</test>
</xml>
I would like to remove the whole id element from the xml leaving it in the following format.
<xml>
<test>
<user>John</user>
</test>
</xml>
How can I achieve this?
Regards,
T.
Remove XML file element
Re: Remove XML file element
Dear tzachk,
supposing you have;
To remove all <Section Name="Connection"> elements, you should use;
To remove all <Users> elements, you should use;
supposing you have;
<ApplicationSettings>
<Section Name="General">
<Key Name="RootPath" Value="C:\mytest\sales" />
<Key Name="Images" Value="\Jpg\" />
</Section>
<Key Name="Server" Value="SERVER04" />
<Key Name="SqlDatabase" Value="PM4Uster" />
<Key Name="TrustedConnection" Value="0" />
</Section>
<Section Name="Agent">
<Key Name="UseAgent" Value="0" />
</Section>
<Users>
<key id="1" />
</Users>
</ApplicationSettings>
~InstallAware Clipboard Data~
~Edit XML File~
~{EB2F4EE3-D72D-46C3-A979-968DE0451E21}~
~C:\XMLFile2.xml~
~UTF-8~
~0~
~ApplicationSettings\Section~
~"Name,Connection"~
~3~
~FALSE~
~FALSE~
~TRUE~
~Edit XML File~
~{7CB09363-E6EC-4173-8EB1-3FDF97531DA9}~
~C:\XMLFile2.xml~
~UTF-8~
~0~
~ApplicationSettings\Users~
~3~
~TRUE~
~FALSE~
~TRUE~
Hi Francesco,
Thanks for your reply. I already tried it but it doesn't work for me. I did some testing and found out that my issue happens because of a minus character '-' between elements.
I've included your xml schema while changeing the value in the key element under Users.
Try the following to replicate:
Try to remove the ApplicationSettings\Users element. It shall fail. I tested this xml schema against w3 validator and it passes.
Please let me know what can be done.
Tzach
<Key Name="RootPath" Value="C:\mytest\sales"/>
<Key Name="Images" Value="\Jpg\"/>
</Section>
<Key Name="Server" Value="SERVER04"/>
<Key Name="SqlDatabase" Value="PM4Uster"/>
<Key Name="TrustedConnection" Value="0"/>
</Section>
<Key Name="UseAgent" Value="0"/>
</Section>
<Users>
<key>-</key>
</Users>
Tzach
Dear Tzach,
unfortunately, our command can't be used with that element ... you may try to read the entire XML file using "Read from Text File" and then, to parse its content in order to remove that element. Finally you can save it using "Write to Text File" command.
Hi Francesco.
This issue needs to be resolved as it prevents altering XML files properly.
Regards,
Tzach
Regards,
Tzach
Users browsing this forum: No registered users and 27 guests
