Find All Files makes the installer hanging
samira
Post by samira »
Hi ,
I have below code in my installer and it makes the whole setup hanging and I noticed the reason is Find All Files.
if Variable CopyLocalCalc? Equals (Ignore Case) TRUE
Read from Text File #READALL\$PreviousLocation$\Server\CalcFieldFiles\DefineCompany.cff into Variable CompanyName
Parse String $CompanyName$ into Variables and CompanyName (Split at first occurrence of pattern)
if Variable CompanyName not Equals (Ignore Case) NoCompany
Find All Files in path $PreviousLocation$\Server\CalcFieldFiles\*.cff, write result into variable CustomizedCFF
for each Element EachFile in | delimited Collection of $CustomizedCFF$ do
if Variable EachFile Contains $CompanyName$
Parse String $EachFile$ into Variables CustomizedPath and CustomizedFileName (Split at last occurrence of pattern)
Parse String $CustomizedPath$ into Variables and CustomizedPath (Split at first occurrence of pattern)
Parse String $CustomizedFileName$ into Variables CustomizedFileName and (Split at first occurrence of pattern)
Copy Local Files $CustomizedPath$\$CustomizedFileName$ to $TARGETDIR$\Server\CalcFieldFiles\$CustomizedFileName$
next
Copy Local Files $CustomizedPath$\DefineCompany.cff to $TARGETDIR$\Server\CalcFieldFiles\DefineCompany.cff
Can you please advise ?
Samira
Re: Find All Files makes the installer hanging
Dear Samira,
without the possibility to verify your code, it is really difficult to give you an answer.
Anyway, the "Find all Files" can take time to complete its process and this depends on the number of files that are present with the target folder.
samira
Post by samira »
Hi Francesco,
This is my code :
~InstallAware Clipboard Data~
~End~
~{2374E4B5-4393-45EA-B3B6-FD025E98086F}~
~End~
~{F92CDB72-4B3E-410D-A666-5710F419380D}~
~Copy/Move Local Files~
~{60DD63F3-23EA-4EFA-A8FE-AE299FA9AE58}~
~$CustomizedPath$~
~DefineCompany.cff~
~$TARGETDIR$\Server\CalcFieldFiles~
~DefineCompany.cff~
~TRUE~
~FALSE|FALSE~
~MessageBox~
~{0DB72673-BB19-4B0C-97FF-0DD06AD1C2D8}~
~CustomizedPath=$CustomizedPath$~
~0~
~1~
~MessageBox~
~{2FA102C8-0F49-4E57-9655-0EE99CE0628D}~
~End of loop~
~0~
~1~
~Next~
~{367CE53F-4ADF-47CB-BA57-6E57CD80EE25}~
~End~
~{2ED04391-AD96-4442-BE1C-F7E2D83D6BEA}~
~{B725A018-C96B-401F-8B92-70ADC49498F5}~
~$CustomizedPath$~
~$CustomizedFileName$~
~TRUE~
~FALSE|FALSE~
~MessageBox~
~{C4FC995F-7EFA-4A27-8852-A822944F4970}~
~CustomizedFileName=$CustomizedFileName$~
~0~
~1~
~MessageBox~
~{0343297A-E444-4E60-9511-04308EB89D3E}~
~CustomizedPath=$CustomizedPath$ ~
~0~
~1~
~Parse String~
~{1A0F7D63-79B8-4CFA-904D-D06D7CC14253}~
~CustomizedFileName~
~0~
~FALSE~
~TRUE~
~Parse String~
~{F1591714-5A0B-4DEC-AF51-3CDEFA173203}~
~$CustomizedPath$~
~CustomizedPath~
~0~
~FALSE~
~TRUE~
~Parse String~
~{208D2E78-0D26-4432-8DE6-16B58C7EDB74}~
~$EachFile$~
~CustomizedPath~
~1~
~TRUE~
~TRUE~
~MessageBox~
~{C2CC49CD-C5E0-45AD-AB1E-C3F0F391235E}~
~EachFile=$EachFile$~
~0~
~1~
~If~
~{8857B9E4-8925-40EE-A96B-71907628F101}~
~EachFile~
~1~
~$CompanyName$~
~FALSE~
~For Each~
~{499B99C1-189A-409C-9B4E-A259F2FAC2C2}~
~EachFile~
~$CustomizedCFF$~
~MessageBox~
~{A1DB4BEE-05FC-49B6-8E9A-54E01BB9845E}~
~CustomizedCFFWithPaths=$CustomizedCFF$~
~0~
~1~
~Find All Files~
~{3669AECC-08BD-4D6C-B0E3-644E740A69CA}~
~$PreviousLocation$\Server\CalcFieldFiles\*.cff~
~FALSE~
~FALSE~
~CustomizedCFF~
~If~
~{75D198AF-12EB-4698-9AA3-43A5D2C7BB7E}~
~CompanyName~
~4~
~NoCompany~
~TRUE~
~MessageBox~
~{39B99FDC-2139-43D6-BEE4-1E725F0CCF7A}~
~CompanyName=$CompanyName$~
~0~
~1~
~Parse String~
~{E41117CC-D221-4A1B-8D33-A8BA4035C473}~
~$CompanyName$~
~CompanyName~
~0~
~TRUE~
~TRUE~
~Read from Text File~
~{E1F07FC5-B932-4FC5-972F-FD701AD1D769}~
~#READALL\$PreviousLocation$\Server\CalcFieldFiles\DefineCompany.cff ~
~CompanyName~
~If~
~{17C46B2C-72A1-4F28-88B5-CDFC34C9DEFD}~
~CopyLocalCalc?~
~4~
~TRUE~
~FALSE~
Thanks for your help
Samira
Dear Samira,
I didn't mean this ... I can even check your code, but if the command hangs, it may depend on the number of files the command have to parse ....and of course, this can require some time.
samira
Post by samira »
Dear Francesco,
I don't think it is because the number of files that my installer hangs I tried only with 1 file and waited for 10 mins or more but still it only shows that it is still in find all file !
Samira
samira
Post by samira »
Hi ,
I also noticed if I install it with out using find all files and it copies the file from the old location to the new location and then I un-install it and delete the folder and add back find all files command then it doesn't hang so it means it only hangs when the first time it tries to find the file !
Dear Samira,
I can assure you that "Find Files" has nothing to do with your possible issue, instead I see that you are using "Copy/Move local files" command with your code.
When do you execute the code in your setup sequence?
... "Copy/Move local files" is a Windows Installer command and its execution is deferred to Apply Install execution, unless you use the IA NATIVE ENGINE.
samira
Post by samira »
Hello
I added message box before and after Find All Files and I can get the message box before it but not the one after it. So I', pretty sure it is hanging there. I have around 20 files in the folder I waited for more than 1 hour but it doesn't return :(
So basically I have sth like this but it doesn't work:
MessageBox: , CustomizedCFF=$CustomizedCFF$
I changed the location of setting NATIVE_ENGINE to True and din't help
Can you please help me on this issue ?
Samira
Dear Samira,
I just tested the command and I am not able to replicate the same.
I suppose there is something else causing your problem.
Please try with releasing a very minimal project that demonstrates the issue and I'll have a look.
