Write Registry Persist - plugin (Freeware)
Thanks for your super quick turn around.
I removed the old version and installed this version. The error has changed to:
Failed to compile plug-in action: Write Registry Persist
I notified support@installaware.com to see if they are getting the same thing with IA9.
again, let me know if you'd like me help in any way.
hi tj. i can't find any problem to fix. sorry. i've tried on two other machines and all works slick as can be. i guess i would just ask you to make sure you have the new dll and not the old one still. but if you say the behaviour is changed you must have a new dll.
have you tried to re-add the plug-in into your IA9 project? (that's all i can think of).
anyway, i don't think i can help further (since i can't make the problem happen). sorry.
It worked very well for me too! I have no idea why it doesn't work on your system, sorry...
Thanks a lot for the quick update on the plug-in
I tracked this down to something I can reproduce.
Try a tiny test app with more than one call to the plug-in.
It works for me with one call. It fails with two or more.
I also noticed that if I hit the "Compile" button twice, I get the error even with one call to the plugin. Don't know if that would help with troubleshooting.
Let me know if you guys don't see the same thing. I've uninstalled and cleaned my box of all IA and plugins and reinstalled everything but I'm still seeing this behavior.
I am also able to reproduce the error with consecutive calls to the plug-in.
Other plug-ins updated for InstallAware 9 don't seem to exhibit this behavior, so I would think this is a plug-in bug.
Please let me know if you need any help from us during resolution.
Sorry to have to report yet another plug-in bug here...
When the plug-in is called at least once, the $NEWLINE$ variable no longer resolves to #13#10 - the carriage return/line feed sequence.
Therefore, it seems that the plug-in might also be corrupting runtime variable lists.
Okay here is the corrected plugin. I'm not sure about a $NEWLINE$ problem. If you want to write a multiline string to the registry you still have to concatinate the values into one variable beforehand. When viewing later, since regedit doesn't allow these values, you just see two little squares. I probably just don't know how to recreate the problem you are describing.
WriteRegPersist.exe
WriteRegPersist.exe
Hi Steve,
Good news: The plug-in builds successfully in consecutive builds.
Bad news: $NEWLINE$ corruption is still there.
Try something like this to see what the bug is:
The expected result is:
The actual result is:
If the plug-in is not called, the $NEWLINE$ variable does not get corrupted...
Set Variable VAR to
Write Registry Persist Key HKLM\\SOFTWARE\\MimarSinan\\test, data
Set Variable VARX to
MessageBox: pers, $VAR$$NEWLINE$$VARX$
pers
OK
OK
OK
pers
OK$NEWLINE$OK
OK
Looks like this compiles and builds just fine now.
I haven't put it through the paces of an install just yet (takes a while) but I'm not sure what the $NEWLINE$ issue was either.
Michael, please see if you can reproduce the error you mentioned with this version?
Stevew, THANKS A TON for your quick response. I'm up against a late quarterly release so the quick turn around on this has been a HUGE help!
Much appreciated,
tj
Much appreciated,
tj
Yep, tested above with the latest version. Variable corruption could be pretty serious.
I've also got nothing but good news this time round, the variable lists are no longer getting corrupted and $NEWLINE$ is back to resolving properly
Great job!
Great job!
Users browsing this forum: No registered users and 68 guests
