i need to set some variable inside IA from a C# function.
i know that with IS and his refernce "InstallShield.interop.msi" i can handle the custom action,
is there something similar?is this possible?
thanks
Riccardo
HELP with setting variables from C# function
Riccardo_Amico
Re: HELP with setting variables from C# function
Dear Riccardo,
this is possible via IA Plugin. Please refer to the "Plug-In Authoring Overview" topic available with the InstallAware documentation.
In addition search for "Dot NET plugins" or "Net Bridge Plugins" in the "Plug-In Development" Forum.
Riccardo_Amico
Hi francesco,
i read all this post "Bridge plug-in runtime error", i tryed to follow all the steps,but it doesn't work.
i am very new , and if you can help me, i will follow all the steps that i need to do.
can you please tell me every single step?or give me a working sample in this way i can study it.
thanks
Riccardo
thanks
Riccardo
Dear Riccardo,
with the link below is available a ready to use "Net Plugin sample".
http://www.installaware.com/forum/viewt ... f=3&t=8868
The above sample includes also the VS 2010 Net C# projects with the full source code and it demonstrates with very basic coding, how to handle InstallAware variables during a plugin execution.
Riccardo_Amico
hi Francesco,
i tryed to watch your sample but i can't download it, because i can't find the file, and the page showed me the error attached below.
thanks
Riccardo
thanks
Riccardo
- att.PNG (21.78 KiB) Viewed 7454 times
Riccardo,
If Francesco is okay with my suggestion, let him contact you by email and he can give you my email address. If you then contact me, I can send you a working example of a plugin. I can answer any questions you might have.
Riccardo_Amico
hi bokkie,
yes no problem if you or Francesco want to contact me.
thanks
Riccardo
thanks
Riccardo
Dear Riccardo,
contact me at [email protected] and I'll send you Peter's email address.
Thanks Peter!
Thanks Peter!
Thanks Francesco. Riccardo, over to you.
