Detect MS SQL Instances cancellation
ranquild
Post by ranquild »
I use "Detect MS SQL Instances" plugin with progress dialog (non-modal). It usually takes few seconds for the command to execute. If setup is cancelled during this call I get a message box with "Setup cancelled" text after confirming cancellation. Is there any way to suppress this message box? Image is attached.
Display Dialog: progress, use as progress dialog (non-modal)
Detect MS SQL Instances : get result into variable INSTANCES
Re: Detect MS SQL Instances cancellation
Dear Ranquild,
using the Dialog Editor, you should chance the "Object Behavior" rule defined with the Cancel button of your progress dialog.
By default this uses "Cancel Setup" ... you may use "Return from Dialog" instead.
