I use Installaware X Studio, and have been successfully signing exe and msi files with a PFX Certificate under Windows 7.
Upgrading to Windows 10, my Installaware X Studio fails to sign.
Comodo advise that the Private file might be corrupted, and advise to get replacement Keys.
KSoftware advise that since I exported my PFX before upgrading to Windows 10, this can not be the issue.
Does anyone have a similar experience, and a recommended solution?
PFX Windows 7 to 10
emmertonland
Re: PFX Windows 7 to 10
I have checked by using KSign from KSoftware.
KSoft will sign the exe but not the msi
emmertonland
SOLVED
To resolve this problem I replaced the Verisign TimeStamp with the http://timestamp.comodoca.com Comodo TimeStamp.
According to the Comodo support literature:
" Our time stamping server automatically selects the appropriate signature algorithm (RSA/SHA-1, RSA/SHA-256 or RSA/SHA-384) with which to sign each timestamp"
https://support.comodo.com/index.php?/K ... ing-server
happy you solved!
Anyway, It must work also with; http://timestamp.comodoca.com/rfc3161
It's the one I use and the predefined one in IA X4.
