Variables in dialogs - label captions
andrejzr
Postby andrejzr » Mon Jul 24, 2006 3:39 pm
I want to use the variables for certain labels in the dialog. It works fine, but there is one problem, appearing minor at first, but unacceptable for the installer of the released product.
The problem is, that when showing the dialog (entering the dialog) and also when leaving it, the labels, that should show the variable values, are displayed as $VarName$ (VarName is the actual variable name) for a very short period of time. On a fast computer this might not be so obvious, but it is displayed.
I guess this is a problem with the dialog processing variable values - they should be processed before the dialog is shown, but it looks like the variables are processed after the dialog is already shown.
Can I expect a fix to this problem in the near future?
Andrej.
andrejzr
Postby andrejzr » Thu Aug 03, 2006 4:01 am
Any comments on this issue?
Postby MichaelNesmith » Thu Aug 03, 2006 5:10 am
AFAIK its pretty hard to see this. Try using a Hide Dialog command after your Display Dialog commands - see if that helps. It might cause more visible flicker but might resolve your problem.
andrejzr
Postby andrejzr » Thu Aug 03, 2006 5:13 am
This is not the solution. If you install on slower computer, it is quite visible. I don't need the fix immediately, but would need to get it in few week time. Our quality control will not allow such things to be visible in final release.
Postby MichaelNesmith » Thu Aug 03, 2006 5:19 am
Sorry, I'm just trying to help out here - I have no control over development's schedule or plans, nor do you. We have fully unlimited 30 day trials available, so if InstallAware doesn't work out for you for any reason, you are free to walk away.
