I created an own dialog to check for a serial number. Now I want to translate it, but it does not appear in the IA Translator. To make the dialog work I also had to include the dialog ".dfm" and ".dfm.miaf" as creatives - maybe this is the reason. How do I include this dialog and make it translateable?
Regards,
Steffen
Own Dialog does not appear in Translator
Are you running 6.01 (SP1)?
If not you may either want to update or try this translator here:
http://www.installaware.com/forum/viewt ... translator
Martin Rothschink
AxoNet Software GmbH
Steffen,
Why is your dialog ending in .dfm2? It should end in .dfm only to be picked up by the translator.
When you swap to the code view, can you see your dialog in the Project Manager? If not, please add it there, and try again.
If that doesn't resolve your issue, please let me know the name of your dialog file, its exact location, the exact location of your .MPR file, and its contents (you can upload the .MPR here).
Ah, you do need to add custom dialogs to your project - otherwise they won't work from your script either.
Users browsing this forum: No registered users and 180 guests
