Installer disappears for a minute after the second progressbar
BorisB
Post by BorisB »
When I start my Installer two progress bars appear. After the second progress bar with a text like "InstallAware is preparing the InstallAware Wizard which will install this application. Please wait" the Installer completly disappears. This can take two minutes or more till the actual wizard is launched. This issuse does not happen on every computer.
Thank you in advance,
Boris
Re: Installer disappears for a minute after the second progressbar
Dear Boris,
this behavior can be caused by another process running with the target machine...typically, this can be due an intrusive Anti Virus.
You should Always test your packages on a Clean Machine where exclusively the OS is installed.
BorisB
Post by BorisB »
FrancescoT wrote:Dear Boris,
Hello Francesco,
thank you for your response. I run my setup on a clean machine. Also on this computer I could see a delay of roughly 25 seconds
Regards,
Boris
Dear Boris,
does your setup logic execute/run/call any task before to display the first setup dialog?
BorisB
Post by BorisB »
Hello Francesco,
I have added some setup logic, but it should not impede startup time on a noticeable level. I have added the code below.
Set Variable MYAHLOGO to TRUE
Set Variable MYAH_DISABLE_VISTA_RESTART_MANAGER to TRUE
Set Variable MYAH_DISABLE_ROLLBACK to TRUE
Set Variable NATIVE_HARDLINK to TRUE
Set Variable NATIVE_ROLLBACK to FALSE
Set Variable NATIVE_OVERRIDE_NON_RESTORABLE_PERMISSIONS to TRUE
Set Variable NATIVE_OVERRIDE_PERMISSIONS to TRUE
Set Variable NATIVE_OVERWRITE_OLDER to TRUE
Set Variable NATIVE_OVERWRITE to ALWAYS
Set Variable NATIVE_ERROR to IGNORE
Set Variable DELAYUNTIL_APPLYCHANGES to FALSE
Set Variable SILENT to FALSE
Set Variable SAVEDATA to FALSE
Set Variable MYAH_TIMEOUT to 10
Set Variable MYAH_COMPRESS_INSTALLER_CACHE to FALSE
Set Variable ABORTONERROR to TRUE
Accelerate Windows Installer ( disable System Restore, disable file costing, disable verbose progress )
Comment: Disable sliding between dialogs
Set Variable FX to NONE
Get Environment Variable %ProgramData% into Variable ProgramDataPath
Set Variable LOGGED to $ProgramDataPath$\ProgramName®\Install.log
Regards,
Boris
Dear Boris,
the delay you are reporting cannot be caused by those variables. You should check if there is anything else in your script that may cause such delay.
Please also consider that a possible minimal delay, it may caused by the check operations performed by the included application RTMs (if any included).
Last but not least; because your setup is based on NATIVE ENGINE (Set Variable NATIVE_ENGINE to TRUE), it doesn't make any sense to set the variable "MYAH_DISABLE_ROLLBACK" and to call the "Accelerate Windows Installer" command. These only work with a MSI based setup.
Finally, the IA engine already sets by default "MYAH_TIMEOUT=10" ...so it's useless to set this to 10.
aimcorp
Post by aimcorp »
I have the same problem.
I am trying to run a patch, on several computers, the patch work fine, but on some computers, the installers disappear and never execute.
Will try without Antivirus.
Any suggestions?
aimcorp
Post by aimcorp »
I still having the same “issue” for more than three months
The installation of main program work fine, but when apply a patch, on some computers is flashed away and the installation screen never opens.
This is happening randomly. I have done everything; deactivate the antivirus, uninstall the antivirus, get rid of firewall, check for others antivirus…
Nothing works on those few machines.
I think the problem is the patch itself, because I have other applications on those machines and the patches apply no problem and I am using similar installations in all.
Any thoughts?
aimcorp
Post by aimcorp »
I have experienced this behavior in few customers computers, that ran our application before (previous year).
I set Windows Defender to stop checking everything, but still the first and second screens opens, and then disappear
Any help will be gladly appreciated.
You should provide some more details about the issue.
Does it happen when installing a compressed setup.exe?
At any rate, I don't think that this may be due Windows Defender.
aimcorp
Post by aimcorp »
My version: Installaware X15
Hello
This is never fixed?
I did a total new installation script.
Then after few days I did a new patch file.
Still in some machine the patch appear and dissapear without installing the patch.
Any suggetions?
Ariel Maisonet
president Aim Corp
JohnGaver
Post by JohnGaver »
Your patch is compiled from your very same source script(s), where the #BUILDMODE# pre-defined Compiler Variable (see their full list at http://www.installaware.com/mh52/deskto ... iables.htm) is set to PATCH.
You may therefore normally log and debug it as with any other part of your setup to see what is failing on affected devices.
John Gaver
InstallAware Skunkworks
