EV Code Signing certificates
pb_man
Postby pb_man » Mon Aug 01, 2022 2:22 pm
The entire security world is forcing EV, or token based certificate signing beginning in November of this year. What is the plan to allow InstallAware to work with this method of authentication? Right now I see no updates, only a topic from 5 years ago saying you had no plans to udpate for this technology. But now we are being forced to use it, so what is the plan for InstallAware?
Re: EV Code Signing certificates
Postby FrancescoT » Tue Aug 02, 2022 12:32 pm
I suppose you are missing that EV code signing is already supported.
https://www.installaware.com/right-edition.htm (SHA 256 Authenticode Code Signing, EV Certificates)
castorus
Postby castorus » Wed Jun 19, 2024 3:00 am
Could you please guide on how to EV Code Signing with Installaware X13?
JohnGaver
Postby JohnGaver » Fri Jun 21, 2024 11:07 am
Please upgrade to InstallAware X14 (or newer) for built-in extended verification certificate support.
You may also use Build Events as an alternative, if you would not like to upgrade at this time:
www.installaware.com/build-events.htm
John Gaver
InstallAware Skunkworks
BartWilson
Postby BartWilson » Mon Jul 22, 2024 1:42 pm
JohnGaver wrote:Please upgrade to InstallAware X14 (or newer) for built-in extended verification certificate support.
http://www.installaware.com/build-events.htm
John, I'm curious if there is documentation in how we can use InstallAware for Extended Verification? I have an EV cert that is stored in an Azure Key Store currently and the only way I have it working is through the Build Events. However if I need to build and sign a new application runtime for hosting on the internet, that isn't as easy to do through Build Events (although I haven't tried) than if the hooks are done through the Authenticode Signature.
I see the Key Container Name and CER mentioned but haven't found any documentation how to hook everything together for talking to something like Azure.
JohnGaver
Postby JohnGaver » Tue Jul 23, 2024 8:21 am
Great to hear from you, Bart!
It would be awesome to have your command line(s) shared. It may not be too much more effort than what you've already accomplished for signing the final package binaries.
To clarify, you're not using Azure Code Signing / Trusted Signing Integration, but some kind of other Azure service to store your EV certificate online - or are these one and the same thing?
From what I understand, EV certificates always require some sort of dongle and thus are the public enemy of build automation across devices, as the dongle needs to be plugged in physically to the build device. However Azure Code Signing works around this limitation, while providing a level of trust that even exceeds that obtained via EV certificates.
John Gaver
axisuser
Postby axisuser » Tue Jul 23, 2024 11:48 am
I have InstallAware 16, does the extended verification tab get around the need for a token? We do our install builds in automation and there is no way to apply a usb dongle.
How does Install Aware works with the extended verification requirement?
Do I need to purchase my ssl cert a specific way?
JohnGaver
Postby JohnGaver » Wed Jul 24, 2024 3:37 pm
axisuser wrote:I have InstallAware 16, does the extended verification tab get around the need for a token? We do our install builds in automation and there is no way to apply a usb dongle.
There's unfortunately nothing we can do to rewrite the physical requirements of the EV technology stack. That'd break the entire EV technology foundation, something it was designed to prevent.
BTW you shouldn't buy an SSL certificate, but an EV code signing certificate - if you want an EV one, that is. You could also get an OV one, of course.
John Gaver
BartWilson
Postby BartWilson » Wed Jul 31, 2024 4:24 pm
JohnGaver wrote:Great to hear from you, Bart!
We have our EV Certificate in an Azure Key Vault and thus I'm calling the azuresigntool.exe to do signing of certain files outside of the Installers right now as they require an EV certificate. Obviously the command line for the usage of the signtool is very similar to using the signtool that gets installed with InstallAware but requires a bunch of keys that allow connecting to the Azure Key Vault:
azuresigntool.exe sign -kvu <vault> -tr <timestampURL> -td sha256 -fd sha256 -kvi <kvclientid> -kvs <kvclientsecret> -kvc <kvcert> -kvt <kvTenantId> file
I asked my question as it would be great if InstallAware would have the ability to put this type of configuration inside of it to do signing. Otherwise when our current cert that doesn't require the dongle expires, we are going to have to do all build events in the installers to do signing as we have multiple build systems that do InstallAware builds and are in DataCenters which makes using a dongle difficult.
It seems like the Azure Key Vault acts like a HSM.
JohnGaver
Postby JohnGaver » Wed Jul 31, 2024 4:59 pm
Thanks for the details!
How many data centers are you supporting right now?
This helps us internally justify and escalate your Azure Key Vault request, among other things.
John Gaver
axisuser
Postby axisuser » Thu Aug 01, 2024 11:05 am
What code sign certificate vendor did you go with? I've look at SSL.com (hidden fees), DigiCert, and GlobalSign.
What is Azure's HSM cost structure?
BartWilson
Postby BartWilson » Fri Nov 01, 2024 2:08 pm
Sorry for the delay here as I've been busy.
So I'm no expert here but it seems like the Premier pricing Azure Key Vault (not the full HSM application) will allow for creating a CSR that is FIPS 140 Level 2 compliant. Went through a POC doing this back in February of this year using the Globalsign document here:
https://support.globalsign.com/code-sig ... -Key-vault. We had been using Globalsign for doing our code signing before with a pfx file on each build box and found their pricing to be a bit less than DigiCert.
Right now in the POC I'm doing all of the signing through the Azure Key Vault within our internal network and have tested doing the azuresigntool on multiple systems internally. When I look at the library/binary files after signing, everything looks OK. Recently I'm working on shifting from the POC Azure Key Vault to our production Entra ID Domain in Azure and was able to copy the POC certificate by exporting it in a PEM and then importing in the new Azure Key Vault with premier pricing. The quick test of the azuresigntool worked without issue.
At the beginning of this thread I said I'm not an expert but maybe someone else can chime in that if the CSR I generated in the Azure Key Vault with premium pricing wasn't FIPS 140 Level 2 compliant, I would have assumed that the Globalsign EV Code Signing certificate that we purchased (passed in the CSR into it) would have said it wasn't compliant. How smart is that CSR check? I don't know.
axisuser
Postby axisuser » Sat Nov 02, 2024 12:22 am
I ended up using google hsm and a global sign code cert. This is so wildly cheap compared to the other vendors with there own signing tool. Ssl.com would have been around $15k/year but with Google hsm we are paying less then $100.
BartWilson
Postby BartWilson » Mon Jan 13, 2025 3:59 pm
John I just realized that you asked a question regarding the Azure Code Signing compared to the Azure Key Vault. They are indeed different services based on what I'm reading. I didn't know Azure Code Signing existed until I started reading about the Code Signing Hooks that was added into the InstallAware X17 release. It does look like the Azure Trusted Signing is designed to have everything integrated into one place whereas what I setup requires a bunch of manual stuff to be done like purchasing a certificate from GlobalSign and then connecting it into Azure Key Vault. Then back into GlobalSign to finalize the cert. The way I read this process is all integrated into Trusted Sign but I'm not confident without using it. It does look like we would pay more money for the Trusted Sign service than what we are paying with the Cert created in GlobalSign and using the Azure Key Vault for signing.
As another FYI, I just tested the Code Signing Hooks in X17 today through our Azure Key Vault setup and it worked perfectly for what I used to see when signing with a "pfx" file.
JohnGaver
Postby JohnGaver » Tue Jan 14, 2025 7:56 am
Oh wow, more expensive by how much?
Glad to hear Code Signing Hooks are working out for you!
John Gaver
Users browsing this forum: No registered users and 51 guests
