Assuming InstallAware created a single file setup file with the name MySetup.exe.
Later this file will be renamed to MySetup123.exe.
Is it possible, to retrieve this new name during the installation process and use it in a variable?
$EXEFILE$ delivers C:\ProgramData\mia*.tmp\MySetup.exe
$SETUPPATH$ results in the path of MySetup123.exe but without filename.
Getting filename of the setup file itself
Re: Getting filename of the setup file itself
You may try:
Set Variable SETUP_FILENAME to $EXEDIR$
Extract File Name Only: SETUP_FILENAMEFrancesco Toscano
pfennig
That's what I did.
The result is MySetup, becaue the unpackaged file in C:\ProgramData\mia*.tmp\ has the original name. I want the name of my renamed file MySetup123.
Since the pre-defined variable SETUPPATH correctly results in the path of my renamed MySetup123.exe, it should be possipple to get MySetup123.exe or MySetup123 as well.
Yes, using the above approach but on "SETUPPATH" (in place of EXEDIR) you should be able to get the name of your renamed file.
pfennig
You see, I tried this before my initial post.pfennig wrote: $SETUPPATH$ results in the path of MySetup123.exe but without filename.
Try with "SFXFILE" pre-defined variable.
I just tried it and it returns the file name of the self extracting exe (as it is).SFXFILE: If an uncompressed directory layout is used, this variable is empty. Otherwise set to the file name of the self extracting executable which bootstrapped the installer.
pfennig
Yes, thank you, this is the one I was looking for.
pfennig
I have to take that back
$SFXFILE$ results in the correct filename only when the setup executable locates on a local drive. Starting it from a network drive, e.g. a NAS, it gets garbled.
local - myglasstest_2211.exe
network - muqsfh~q.exe
This topic applies to InstallAware Multi Platform as well.
Are you reporting a bug with some of the pre-defined variables at play here:
http://www.installaware.com/mh52/deskto ... iables.htm
$SETUPPATH$ is really the most top-level variable at play.
But if $SFXFILE$ and/or $SFXPATH$ are corrupt, I can't see that working properly either.
Did you also have a chance to look at $GPOPATH$?
If you could let me know which work properly on network paths, I'll then escalate this to R&D for priority actioning.
John Gaver
InstallAware Skunkworks
I did a try and I don't see any problem with the value returned by the variables; SETUPPATH, SFXFILE, SFXPATH, and GPOPATH. For what I see all these variables work as documented.
However, if you believe there is a problem, please provide a very minimal project that demonstrates the issue.
