Windows 11 progress broken
MartinIW
Post by MartinIW »
Hi there,
we are using InstallAware for several years now to build our setups for our customers.
Recently we tested it on a windows 11 machine and wonder what happened to the progress than runs when we are installing. Did we do something wrong or why is it only showing those placeholders instead of the files that are beeing installed? Oh and we are using InstallAware X15 btw.
What are we doing wrong or is it just not possible in windows 11 to show the correct progress?
Thanks in advance,
Martin
MartinIW
Re: Windows 11 progress broken
Post by MartinIW »
Does anyone have any ideas?
sinan
Post by sinan »
Grab the latest update and set the NODROP compiler variable to TRUE.
MartinIW
Post by MartinIW »
Hello sinan,
what do you mean with grab the latest update? We are using InstallAware X15 now.
Do we need to update to a newer Version to get this running?
Thanks in advance,
Martin
rikmar67
Post by rikmar67 »
I upgraded to x16 and set the NODROP compiler variable to TRUE. My install is unchanged. The progress text on a Windows 11 machine still shows "Copying new file: [1], Directory: [9], Size: [6]" instead of the actual file names. Does anyone have a real solution to this issue?
rikmar67
Post by rikmar67 »
Disregard the previous post. Full instructions on how to change a compiler variable were not provided. Previously I just added SET VARIABLE NODROP to TRUE in my MSI script. That was not correct and had no affect. Instead, go to the Project tab, select Project Settings, then from the tree select the Project > Compiler Variables node, add a new compiler variable for NODROP and set the default value to TRUE. My install on Windows 11 machines now show the complete file names instead of "Copying new file: [1], Directory: [9], Size: [6]".
pfennig
Post by pfennig »
I think this should be added to the InstallAware GUI under Power Tweaks, where one has access to most of the Pre-Defined Compiler Variables already.
JohnGaver
Post by JohnGaver »
pfennig wrote:I think this should be added to the InstallAware GUI under Power Tweaks, where one has access to most of the Pre-Defined Compiler Variables already.
You will be pleased to hear this functionality is being rolled out in the next update.
John Gaver
InstallAware Skunkworks
BartWilson
Post by BartWilson »
Is this update in what I see on the downloads page:
Version: X16 (33.14.159.2024)
Released to Manufacturing on: 3.14.2024
JohnGaver
Post by JohnGaver »
That's exactly it.
John Gaver
BartWilson
JohnGaver wrote:That's exactly it.
Thanks! I've confirmed that I could see the option in the Power Tweaks with the version mentioned!
