When I use a setup.exe to install and then uninstall a program there always remains an artefact in the following registry key ...
Computer\HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\"Productversion-GUID"
Value-Name "UninstallString" Value: C\Users}Username\AppData\Local\"Productversion-GUID"\NameOfInstaller.EXE
IMO this is a bug. Not?
General issue with remaining registry entries after uninstall
Re: General issue with remaining registry entries after uninstall
BTW - this registry remains are there when I install and afterwards uninstall with the very same user. So this is not the issue that the install-context might have changed between install and uninstall.
There seems to be the "clean-up" logic of Installaware on uninstall not complete.
And further information - this is happening on a persistent Citrix VM
I will recheck with a local installer on my development workstation and let you know of the outcome.
This also happens on a physical machine.
Interesting:
When I install via MSIEXEC and then uninstall via MSIEXEC under reference to the product version in admin-/systemcontext (e.g. MSIEXEC /X {GUID}) the unistallstring is removed.
The uninstallstring written by the installer is wrong it is MSIEXEC /I {GUID} - where it should be MSIEXEC /X {GUID} - as far as I know.
Interesting:
Are you sure those values are written by your InstallAware setup and not a third party setup you may be shelling to?
The InstallAware setup engine does not employ the notation you have quoted when creating uninstallation keys.
John Gaver
InstallAware Skunkworks
Users browsing this forum: Google [Bot] and 60 guests
