Variables return TRUE but all IF statements fail
RolandBrooks
Post by RolandBrooks »
Using X12 Studio edition. I manually created a Ukrainian language translation.
The following MSI code returns TRUE to ISWINDOWS64BIT. However the code always steps into the IF statement as if the variable was set to FALSE.
Get System Setting Windows in 64 bit Mode into ISWINDOWS64BIT
if Variable ISWINDOWS64BIT Equals FALSE
Terminate Installation
This only occurs when I select the Ukrainian language, and not with other languages that are intrinsically part of X12.
JohnGaver
Re: Variables return TRUE but all IF statements fail
Post by JohnGaver »
This topic applies to InstallAware Multi Platform as well.
Check the If statements in your InstallAware Translator.
The default comparison values have been overridden there by a member of your team.
John Gaver
InstallAware Skunkworks
