Read registry value and reboot and resume
Balanced-Plus
Post by Balanced-Plus »
To solve issues when installing SQL Server media on Windows 11 systems I want to read a registry value before Pre-requisite SQL Server Media is installed.
If the value is not available or incorrect it should be added to the registry (ONLY when the SQL instance isn't already installed).
The system needs to be rebooted in order to activate the new value (before installing SQL Server).
Background info: https://learn.microsoft.com/en-us/troub ... ector-size
The code basically looks like the following.
    Set Variable WIZZ_FORCE_SECTORSIZE_WIN11 to
    Comment: Registry uitlezen t.b.v. installatie SQL Server op Windows 11 systemen.
    Read Registry Key HKLM\SYSTEM\CurrentControlSet\Services\stornvme\Parameters\Device\ForcedPhysicalSectorSizeInBytes into WIZZ_FORCE_SECTORSIZE_WIN11
    if Variable WIZZ_FORCE_SECTORSIZE_WIN11 not Equals * 4095
      Comment: Registry waarde toevoegen t.b.v. installatie SQL Server op Windows 11 systemen.
      Write Registry Key HKLM\SYSTEM\ControlSet001\Services\stornvme\Parameters\Device\ForcedPhysicalSectorSizeInBytes, * 4095 (permanent)
      Reboot Computer and Resume Setup
Will it work if I add the section to the "Check SQL Instance"-script (like below)?
Set Variable ISWINDOWS64BIT to FALSE
Get System Setting Windows in 64 bit Mode into ISWINDOWS64BIT
if Variable ISWINDOWS64BIT Equals TRUE
 Check Service State for MSSQL$BALANCEDPLUS2008 (write result into variable MSSQL2022_X64)
 if Variable MSSQL2022_X64 Equals NOTINSTALLED
[b]   Comment: Registry uitlezen t.b.v. installatie SQL Server op Windows 11 systemen.
[/b]   Get System Setting Windows 8 into MSSQL2022_IS8_X64
   if Variable MSSQL2022_IS8_X64 Equals FALSE
     Set Variable OS_SP to
     Get System Setting Windows 2008 R2 into MSSQL2022_IS2008R2_X64
     Get System Setting Windows 2008 into MSSQL2022_IS2008_X64
     Get System Setting Windows 7 into MSSQL2022_ISSEVEN_X64
     if Variable MSSQL2022_IS2008R2_X64 Equals TRUE
       Comment: For Win 2008 R2, at least Service Pack 1 is required
       Get System Setting Service Pack 1 into OS_SP
       if Variable OS_SP Equals FALSE
         MessageBox: $TITLE$ Setup, $TITLE$ requires at least Service Pack 1 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.
         Terminate Installation
       else
       if Variable MSSQL2022_IS2008_X64 Equals TRUE
         Comment: For Win 2008, at least Service Pack 2 is required
         Get System Setting Service Pack 2 into OS_SP
           MessageBox: $TITLE$ Setup, $TITLE$ requires at least Service Pack 2 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.
         else
         if Variable MSSQL2022_ISSEVEN_X64 Equals TRUE
           Comment: For Win 7, at least Service Pack 1 is required
           else
           Comment: at least Windows 7 is required
           MessageBox: $TITLE$ Setup, $TITLE$ requires at Windows 7 sp1 or later. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.
   Set Variable MSSQL2022_X64 to FALSE
   Set Variable PREREQ to TRUE
   Set Variable PRELIST to $PRELIST$$NEWLINE$Microsoft SQL Server Express 2022 (x64)
   else
   Set Variable MSSQL2022_X64 to TRUE
 else
 MessageBox: $TITLE$ Setup, $TITLE$ requires a 64 bit operating system. Please upgrade your operating system and try again.$NEWLINE$$NEWLINE$$TITLE$ Setup cannot continue.
Thanks for your help.
JohnGaver
Re: Read registry value and reboot and resume
Post by JohnGaver »
What happens when you run the code?
John Gaver
InstallAware Skunkworks
Balanced-Plus
My question is more about if someone can look at it if it will work.
Is it added to the right places inside the script?
