.MSI causes "The system administrator has set policies to prevent this installation" error
axisuser
Postby axisuser » Tue Nov 21, 2023 1:50 pm
When setting my InstallAware X16 project to output a .msi file the resulting installation doesn't work on Microsoft servers. I can run the .msi in Windows workstations but not servers like 2016 or 2019. I get the error "The system administrator has set policies to prevent this installation." Why is this the case? These are generic server installations and have no policies set regarding .msi files. If I set the project to .exe then everything works fine. My customers are expecting .msi files. Why doesn't this work?
I'm used to Install Shield where this was trivial.
axisuser
Re: .MSI causes "The system administrator has set policies to prevent this installation" error
Postby axisuser » Wed Nov 22, 2023 2:36 pm
This only happens on servers
BartWilson
Postby BartWilson » Fri Dec 15, 2023 1:08 pm
Could this have something to do with the UAC settings in your IA project file? Many of the projects I work with use the "Elevate Administrators Only (highest Available)" setting. Not sure I tested my .msi installer on a server setup given it is designed to run on a specialized Windows 10 or 11 box.
I saw no one answered here for about a month.
axisuser
Postby axisuser » Fri Dec 15, 2023 2:16 pm
This issue doesn't seem to present itself on workstation but only servers. I think it's UAC related but only in a way that effects IA .MSI files. We have moved to .EXE files for now.
axisuser
Postby axisuser » Wed Jan 10, 2024 12:18 pm
When I run .msi installation from other vendors they run without issue. Only the .msi files created with IA cause the error in Windows servers.
JohnGaver
Postby JohnGaver » Mon Feb 12, 2024 6:57 pm
axisuser wrote:When I run .msi installation from other vendors they run without issue. Only the .msi files created with IA cause the error in Windows servers.
A system policy affecting all MSI files could not logically be affecting only InstallAware built packages.
John Gaver
InstallAware Skunkworks
Users browsing this forum: No registered users and 75 guests
