How do I know that the installer was launched with the /quiet command-line option?
Kostya
Post by Kostya »
We use the Windows Installer "/quiet" switch to install silently:
msiexec /i installer.msi CMDLINE="SOMEVAR=TRUE" /quiet
How would we know that it was run with "/quiet"?
I know, we can get and process variables in the code if we use CMDLINE, but I wouldn't want to pass another variable like that if the switch is present. As far as I understand, the predefined variable SILENT could be used if we run it like
installer.exe /s
and does not help in this case.
Kostya
JohnGaver
Re: How do I know that the installer was launched with the /quiet command-line option?
Post by JohnGaver »
You don't need to worry about manually checking for that command line parameter.
When your MSI is launched silently, your setup will automatically receive the /s command line parameter from the MSI.
If this is not what you are seeing, please describe your workflow in detail.
John Gaver
InstallAware Skunkworks
Kostya
Post by Kostya »
John, you are right, I see that the SILENT variable works perfectly in the case described. Sorry, apparently I didn't check it correctly first here. Thanks!
