Logging Fails
Zudokan
Logging Fails
Postby Zudokan » Wed Aug 14, 2024 4:16 pm
I have setup a batch file to launch an installer and log the results.
"setup.exe" /l="C:\Temp\log.txt"
I have tried both with and without quotes.
No results??
TIA
JohnGaver
Re: Logging Fails
Postby JohnGaver » Thu Aug 15, 2024 4:29 pm
This topic applies to InstallAware Multi Platform as well.
You don't need to use any quotes, since there's no spaces in your path.
If there were, you'd have to quote as follows:
setup.exe "/l=c:\some path\some file.txt"
John Gaver
InstallAware Skunkworks
Zudokan
Re: Logging Fails
Postby Zudokan » Thu Aug 15, 2024 5:15 pm
John,
Thanks, so after walking through every single combination as shown below,
I finally got it to work by enclosing the exe file path in quotes, but not the
log file path.
"D:\Installaware\ProjectName\Test File\Installer v1.0.0.0.exe" /l=c:\temp\log.txt
While this didn't seem to work before, it did today... :oops:
Issue Resolved.
Users browsing this forum: No registered users and 76 guests
