/s massive slowdown after X17 upgrade
Paul Guthrie
Post by Paul Guthrie »
I upgraded from X15 to X17 (1.5.2025)
Now silent installs are taking a very long time and also using 100% CPU and also creating 100's of processes.
Silent install of same setup created using X15 = 81 seconds
Silent install of same setup created using X17 = 563 seconds
also over 500 processes are created while running the setup created by X17 (see screen capture)
If run without the /s switch installation time is normal.
What could be causing this issue?
JohnGaver
Re: /s massive slowdown after X17 upgrade
Post by JohnGaver »
Definitely not an expected occurrence to have more than one process (save 500!) launching!
:o
My recommendation would be to escalate this to official support, so they may respond on the basis of your entitlement.
John Gaver
InstallAware Skunkworks
JohnGaver
Post by JohnGaver »
Fixed in 34.03.
John Gaver
