Setup with Aero theme shows classic Windows7 style on Windows11
anja_laenge
Post by anja_laenge »
we create setups for our customer with InstallAware X14 with Aero theme; on Windows 11 he noticed unwanted transparency effects which we could fix), and an unwanted old classic Windows 7 window style (with the blue title bar, classic colored minimize, maximize, close buttons).
How to fix this?
kind regards
Anja
JohnGaver
Re: Setup with Aero theme shows classic Windows7 style on Windows11
Post by JohnGaver »
Could you please provide screenshots to help us better understand the issue you are running into?
Also, please cross-check your results against the latest version of our Aero Dialogs Sampler using the "Sample the dialogs in this theme" link found at https://www.installaware.com/user-inter ... themes.htm.
If that produces different results, you may want to upgrade to the latest InstallAware version, and/or update the dialogs in your theme with the versions of the dialogs found in the latest version of the Aero theme.
John Gaver
InstallAware Skunkworks
anja_laenge
here are the screenshots:
left is a a new X14 dialog without fixing the transparency, right is your Aero Sampler.
This is a screenshot with removed aero glass element at top left in the dialog editor test
and this is the same during a running setup.
Do I understand your answer correctly, that the dialogs from the latest version will work with the X14 and be correctly compiled into the setup?
Where can I find these?
kind regards
Anja
JohnGaver
Post by JohnGaver »
Ah, that helps a lot! Thank you very much for providing those screenshots,
I believe the issue you're seeing is a bug that's been fixed in newer versions of InstallAware.
You wouldn't even need to swap out your dialogs - just upgrade to the latest version, and recompile.
John Gaver
anja_laenge
Thank you very much.
I will pass on the information.
kind regards
Anja
