Run Program Not Working
vaibhavopkey
Postby vaibhavopkey » Thu Apr 24, 2025 8:44 am
I'm using InstallAware Multi-Platform Version 2025 (2.1) [Windows x86].
The Run Program command always returns -1. I'm using commands that work fine in CMD, but they still return -1 when run through Run Program.
Code:
Run Program cmd.exe echo Hello, World! (WAIT, get result into variable _appsOpen)
if Variable _appsOpen Equals -1
  MessageBox: , $_appsOpen$ apppppppp
  Terminate with Exit Code -1
~InstallAware Multi Platform Clipboard Data~
~End~
~{900F6C01-C5F3-4FB0-94E1-7CBBC988E474}~
~Terminate with Exit Code~
~{4C7C165D-9E70-49E1-96FC-FA7261DAA405}~
~-1~
~MessageBox~
~{036B6704-CE73-49B8-BD48-3CF98F48CE90}~
~$_appsOpen$ apppppppp~
~0~
~1~
~If~
~{DACED6AC-6586-423F-8CC4-EF00C0ABB87B}~
~_appsOpen~
~0~
~-1~
~FALSE~
~Run Program~
~{BD823625-34B1-445A-8929-AC8D2E9B50AE}~
~cmd.exe~
~FALSE~
~echo Hello, World!~
~TRUE~
~_appsOpen~
JohnGaver
Re: Run Program Not Working
Postby JohnGaver » Thu Apr 24, 2025 11:06 am
Have you tried specifying the full path to the program you're trying to invoke?
John Gaver
InstallAware Skunkworks
vaibhavopkey
Postby vaibhavopkey » Thu Apr 24, 2025 11:56 am
I give the full path to cmd.exe (i.e., C:\Windows\System32\cmd.exe), it opens the command line, but my program does not run.
Run Program C:\Windows\System32\cmd.exe /c start "" "$TARGETDIR$\Opkey Execution Agent\ExecutionAgent_Web_NetCore.exe" (WAIT, get result into variable _appsOpen)
Using this code, I want to launch my program's .exe.
Can you provide me with a sample code showing how to launch my application’s executable?
JohnGaver
Postby JohnGaver » Thu Apr 24, 2025 12:44 pm
Yes, launch your program directly and don't use cmd.exe as an intermediary.
You can do the latter if you're interested in running a batch file or similar.
John Gaver
vaibhavopkey
Postby vaibhavopkey » Thu Apr 24, 2025 1:16 pm
The program launches without using CMD, but if I want to quit my running app and then install, how can I do that without using CMD?
JohnGaver
Postby JohnGaver » Thu Apr 24, 2025 1:40 pm
I don't understand the second part of your question - how does cmd help you here?
Can you describe your scenario in a little more detail?
John Gaver
vaibhavopkey
Postby vaibhavopkey » Thu Apr 24, 2025 2:44 pm
How can I close a running application during installation in installaware? The application should be closed first, and then the installation process should start.
JohnGaver
Postby JohnGaver » Thu Apr 24, 2025 4:16 pm
Using the Restart Manager is the best (and official) way to do this on Windows, but since it is not a platform agnostic solution, it is not supported in InstallAware Multi Platform.
John Gaver
Users browsing this forum: Google [Bot] and 41 guests
