Not able to build using commandline
vaibhavopkey
Post by vaibhavopkey »
I'm using installaware multi-plateform,Trying to build using command line,but when i'm running below command,it just open installaware project.
C:\Users\VaibhavDubey>"C:\Users\VaibhavDubey\InstallAware Multi Platform\miamp.exe" "C:\Users\VaibhavDubey\Documents\Plugin Builds\Plugin.mprx" /b=1
C:\Users\VaibhavDubey>miabuild.exe "C:\Users\VaibhavDubey\Documents\Plugin Builds\Plugin.mprx" /b=1
'miabuild.exe' is not recognized as an internal or external command,
operable program or batch file.
JohnGaver
Re: Not able to build using commandline
Post by JohnGaver »
The first command line launches the IDE, and would not build the project.
The second command line would have been correct, had it specified miaxbuild (for InstallAware Multi Platform), instead of miabuild (for InstallAware X17).
John Gaver
InstallAware Skunkworks
vaibhavopkey
It's not working
C:\Users\VaibhavDubey>miaxbuild.exe "C:\Users\VaibhavDubey\Documents\Plugin Builds\Plugin.mprx" /b=1
'miaxbuild.exe' is not recognized as an internal or external command,
JohnGaver
Post by JohnGaver »
Why would it, that's clearly not going to be the folder where it's been installed, is it?
John Gaver
