InstallAware X17 Free failing to run
Omninimbus006
Post by Omninimbus006 »
I am attempting to use InstallAware X17 Free to create an installer for my application. However, whenever I click "Create Setup Project" in Visual Studio 2022, I get this error:
Error while creating setup project: Unable to load DLL 'IaVsExt64.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Checking in the InstallAware installation folder, I can see a file named 'IaVsExt.dll', but no 'IaVsExt64.dll'
I have tried installing InstallAware both through the downloaded installer, and through the Visual Studio Marketplace.
Downloading using the installer does not work, as it says I don't have visual studio installed. (I have Visual Studio 2022.)
Downloading using VS Marketplace appears to work, but causes the above error when I try to use any of the extension's functions.
I am running Windows 10 64-bit.
JohnGaver
Re: InstallAware X17 Free failing to run
Post by JohnGaver »
Checking my folder, I see that it is installed.
Can you please confirm which folder you found the file that you do have within?
Also please confirm the anti-virus software active on your device.
John Gaver
InstallAware Skunkworks
Omninimbus006
I was looking in the install folder I designated when using the installer. (D:\Applications\InstallAware X17\). I am running Windows Defender Antivirus.
JohnGaver
Post by JohnGaver »
Just to confirm, the exact path where you found the file installed is then
D:\Applications\InstallAware X17\IaVsExt.dll
John Gaver
Omninimbus006
It was in a subfolder. Here is the full path: "D:\Applications\InstallAware X17\vsix\IaVsExt.dll"
JohnGaver
Post by JohnGaver »
Path looks good.
But I'm not able to reproduce your issue. I have both the 32 bit and 64 bit add-ins installed just fine (it was E:\Applications for me, but I doubt that makes a difference).
Would you like to try installing our web or single file download manually (after first uninstalling your add-in installed version) to see if that helps, as an initial attempt?
John Gaver
Omninimbus006
I started with trying the web download before using the Visual Studio extension manager, but when I tried to install it it said I didn't have Visual Studio. Here is a screenshot of what happens when I try to install it again using the web installer: Image
My Visual Studio installation is in the default folder, so I'm not sure why the installer can't detect it. I have Visual Studio 2022 and 2022 Preview.
Edit: as the image embed failed, here is the direct link: https://imgur.com/gpu8t57
JohnGaver
Post by JohnGaver »
Can you confirm the exact Visual Studio 2022 installer URL that you downloaded and ran to install Visual Studio?
Also please provide your operating system version, bitness, and the edition of Visual Studio 2022 you installed.
We'll try to reproduce your reports again with those details, as we've been unable to reproduce them otherwise so far.
John Gaver
Omninimbus006
I installed and have been updating Visual Studio 2022 Community using the Visual Studio Installer application. I don't remember where I originally got the VS Installer application, as that was a long time ago, but I think it may have been installed automatically as part of my installing Visual Studio 2019.
I am running Windows 10 64-bit and using Visual Studio Community 17.14.3.
JohnGaver
Post by JohnGaver »
Thanks for the update!
During the delay, I was able to verify that we do support the Community Edition.
I am going to try and reproduce your issue with your exact setup one more time, but I still need to know the exact version of Windows 10 you are using. There's been one each half-year with Windows 10, so there's at least 14 of them. They are usually abbreviated in the form 18H2, 20H1, etc.
I'll just download the latest VS Installer, unless you are able to upload your exact installer somewhere and/or provide the exact download URL where you may have obtained it.
John Gaver
Omninimbus006
I am running Windows 10 Version 22H2 build 19045.5854.
Here is a download link for the Visual Studio Installer I am using: https://drive.google.com/file/d/13zvahk ... sp=sharing
JohnGaver
Post by JohnGaver »
Oh, awesome!
Which workloads did you pick?
John Gaver
JohnGaver
Post by JohnGaver »
So with the "default" workload (not selecting anything and installing just the IDE), I get this error (from Visual Studio itself) during the Add-In registration phase (regardless of whether I choose it inside the VS IDE or the IA setup):
Windows 10 22H2 X64 UEFI-2025-06-03-17-04-04.png (271.85 KiB) Viewed 99124 times
Since the VS project is constantly evolving, may I suggest you bounce this back to them to see what's broken at their end?
John Gaver
Omninimbus006
My currently installed workloads are: ASP.NET and web development, Python development, .NET desktop development (the workload I am trying to use InstallAware with, and Game development with Unity.
Interestingly, the error you have encountered is entirely new to me. I'll try updating Visual Studio to the latest version again and see if I have the same issue.
