Writing DWORD data to the Registry when the Native Engine is enabled
Kostya
Postby Kostya » Tue Jun 17, 2025 9:59 am
For some reason I have to execute the Write Registry command when the NATIVE_ENGINE is set to TRUE. Previously I used a trick with adding "#" to the beginning of the string so that the value in the Registry would be of type DWORD, since the command does not allow to select this data type. But with the Native Engine enabled this does not work. How could I do this now, to write DWORD data to the Registry?
Kostya
JohnGaver
Re: Writing DWORD data to the Registry when the Native Engine is enabled
Postby JohnGaver » Tue Jun 17, 2025 2:24 pm
This topic applies to InstallAware Multi Platform as well.
How do you mean?
Aren't you just selecting the Integer type in the Write Registry command?
John Gaver
InstallAware Skunkworks
Kostya
Postby Kostya » Wed Jun 18, 2025 5:36 am
Ah, that's right, the Integer type is of course what I need in this case. I just used the "#" at the beginning of the string before to write the value as DWORD. Found a mention of this somewhere. It was on the surface. Sorry, and thank you for the tip!
JohnGaver
Postby JohnGaver » Wed Jun 18, 2025 7:37 am
Right, that would probably work with Windows Installer given their internals, but not the Native Engine! No worries :)
John Gaver
Users browsing this forum: No registered users and 80 guests
