so one of our customers has installed the software on a network drive.
For some unfortunate reasons the network drive no longer exists.
The uninstallations failed because the installation folder is not found.
He tried to mimic the old situation by creating another network drive with the installation, but that failed.
When he contacted us, I tried
- https://support.microsoft.com/de-de/hel ... or-removed
- rename the uninstall source so when the control panel did not find it, I prompted the question whether to remove the entry with yes
- backuped and removed [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\MimarSinan\InstallAware\Ident.Cache\{...}]
- backuped and removed HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{...}]
The goal is to enable the customer to work with a correctly installed updatable local version, for which, in my understanding, we need to remove the existing version and reinstall with local targetDir.
Please advice on how to proceed.
Kind regards
Anja
