Unable to Debug
binkle
Unable to Debug
Postby binkle » Mon Sep 18, 2006 9:40 am
I'm completely unable to debug.
Yes, I did switch my project to uncompressed output.
There are no variables in the outputpath. (standard)
The output filename ist just set fix tho "mysetup".
I set breakpoints on the line:
if Variable WIZARD Equals CANCEL
of label: Welcome Dialog
and some other 'if' of dialogs.
I rebuild the setup and used the button with the nice '!', but the setup did not stop on thebreakpoint when the cancel button of the diaglog is pressed.
What am I doing wrong?
Tinus
Postby Tinus » Mon Sep 18, 2006 11:40 am
Harald,
Do not use the ! button, this will run your setup without debugging.
Use the green > button or press F9 to run with debugger.
Martin Rothschink
AxoNet Software GmbH
jimo
Postby jimo » Mon Sep 18, 2006 11:42 am
Try the green arrow instead of the red exclamation mark.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
binkle
Postby binkle » Tue Sep 19, 2006 1:50 am
Oh, I'm sorry,
Stupid me... should read the whole hint.
Thanks!
Users browsing this forum: No registered users and 24 guests
