New variables
Earl
New variables
Post by Earl »
Just to clarify, is the process of creating a variable no more than simply adding a new name in the combo window when you need one? For example, I wanted to check for the machinename, so I just typed in CHECKMACHINE in the Get System Settings dialog.
A nice product, seems fairly easy to work with, but a tutorial would be fantastic. The help file is spotty: sometimes hit right on point, but other times, the most obvious items aren't so obviously specified.
Tinus
Re: New variables
Post by Tinus »
Earl wrote:A nice product, seems fairly easy to work with, but a tutorial would be fantastic.
Not really a tutorial but worth to read:
http://www.installaware.com/installawar ... _guide.pdf
http://www.installaware.com/installawar ... dotnet.pdf
Martin Rothschink
AxoNet Software GmbH
For most commands, that will work. For plug-in commands, variables have to be pre-defined using the Set Variable command. The IDE warns you about this using tip balloons, so hopefully that helps smooth out the experience.
