Can I Get a Users Guide
Superfreak3
Post by Superfreak3 »
We are currently using Wise for Windows Installer and are contemplating a switch to Install Aware.
Is there a User's Guide available for download or is there one included in the Evalutaion?
I'm also wondering how painful a switch this will be. Is there any type of conversion for Wise install templates (.wsi) or do the projects need to be rebuilt?
Just Wondering!!
:wink:
Superfreak3
Is the Reviewers Guide what I'm looking for?
Also, is he only difference between the Studio and Studio Admin versions the ability to imort .msi's and .msm's (basically)? Would/could this be the answer to my Wise conversion question? How would existing Custom Action from my 'Wise world' be imported/resolved in Admin Studio?
Just severl more questions.
Thanks in advance for any info!!
Post by CandiceJones »
Yep, the reviewer's guide would be a good start; also read the Extreme Installers article, its a nice walkthrough.
You're a lot better of re-writing your custom actions in MSIcode. You will see that what took, say 10 lines of C++ code, will most often be 1-2 lines of MSIcode in your new script (the built-in functions help with that). You can also call arbitrary DLL functions and run EXE files from MSIcode, so that should help with the migration.
Correct about Admin Studio - and, there is also the redistributable automation interface (if you don't immediately recognize what that is, chances are you dont need it ;)).
Superfreak3
Cool, thanks.
I'll give 'em all a look!
