change targetdir with startparameter
Zack
Postby Zack » Fri Mar 16, 2007 5:56 am
I tryed to change the targetdir ( "C:/mybuild/myinstaller targetdir=C:/$TITLE$" ) at the start of my installation. But without an positiv result.
With "title=something" it works fine.
The Docu tell me:
To set the values of setup variables from the command line, possibly overriding their default values in the process, specify the variables and their values as follows:
<setup> <VARIABLE_1>=<VALUE_1>
TARGETDIR: Initial value set to <Program>\\Application Title, using the name of the product being installed as the application title.
and
Hope someone can help me.
thanks Olli
Zack
Postby Zack » Fri Mar 16, 2007 6:03 am
update:
found my Problem.
Need to use /s mode to get a positiv result.
neillans
Postby neillans » Fri Mar 16, 2007 2:33 pm
Hi Zack,
Good to hear you found your solution; if you have any further questions, please do not hesitate to post again!
Andy Neillans
Users browsing this forum: No registered users and 16 guests
