MDAC 2.81 installation fails under XP SP1
casic
Post by casic »
Hi there,
using the latest version 6.42 I noticed, that the installation of MDAC 2.81 Refresh fails under Windows XP SP1. The same setup runs on Windows 98SE without any problems. Setups created with a previous version of IA 6.42 installs the MDAC 2.81 under Windows XP SP1.
Are there any changes known about the MDAC 2.81 installation?
Thank you very much,
Markus
Markus Diettrich
Install[b]Aware[/b] MVP
[i]If it can't be done with InstallAWARE then you are not using Windows[/i]
Actually, no:
1. 2.81 is *not* available as a redist for XP SP1.
2. 2.8 *is* available as a redist for this platform.
3. Only XP SP2 can install 2.81 on XP SP1.
See the documentation from MS for more information.
