Hi, I have a problem with the update wizard. I created a patch, added that patch to an update pack, and then assigned that update pack to a version. Whew. Then I posted the updates and the updates.ini file to my "Monitor URL". Run the setup.exe /update from my remote machine and it notifies me of the update. I download it then run it. So far so good.
Now I didn't realize that the 'patch' had a password so I canceled the patch setup. Get the password from the build guy, but now I can't re-run the patch. When I re-run setup.exe /update it silently finishes and doesn't think there is an update to run (when actually there is). Basically, if a downloaded update is interrupted for any reason, it is forever lost, never to be found again.
How can we fix this??
Update wizard problem
