.exe -> .msi, something missing :(
i just made an installer, and tested it as a single .exe, which worked very fine, i have an option with radio buttons were the user selects if the application is to be used for everyone or only the single user.
I preselect everyone, and it works fine in the .exe, but when converting to .msi, there is nothing preselected when i get to that dialogue. Am i missing something, or is it a bug ?
.Simon
.Simon
That's not true according to the InstallAware Reviewer's Guide, which states:neillans wrote:The Group Policy Wizard is really only intended for creating msi's for use with Group Policy Deployment systems; these are not interactive.
Has anything ever come of the questions posed in this thread?The Group Policy Wizard also permits customizing the command line passed to the embedded InstallAware setup, either by hard-coding a command line in the wizard itself, or by setting the public CMDLINE property of the outer MSI at deployment time on end-user systems. Therefore a single MSI file can be made available for use by both end-users and in corporate deployment scenarios using the Group Policy Wizard.
Paul Guthrie
Hi Candice,
Re.
The ability to run the MSI outside of Group Policy Deployment is useful for us as way of testing whether the MSI is working (in fact we don't have any other way.)
Paul G
Re.
Is this in the latest download (Version: 8.01 Last Updated: October 22, 2008)?Group Policy Wizard can now produce MSI files which work both inside and outside Group Policy deployment
Paul G
Paul Guthrie
Hi Candice,
Re.
Paul G
Re.
Paul G
