Custom command line
ddebono
Custom command line
Postby ddebono » Sat Jun 23, 2007 4:44 am
I want to be able to give the setup some custom command line parameters like:
setup.exe /LICENSE:64344554
Also want to be able to set the silent installation using script in the code.
How can I do this in the setup ?
David
Edhy
Postby Edhy » Sat Jun 23, 2007 10:13 am
You can pass variables to your setup.exe like this:
setup.exe /s MYLICENSENO=$UseAVariableNameHere$
In the above example your setup.exe should have a variable name MYLICENSENO and the calling script where you are executing setup.exe wll pass the value you want to use in MYLICENSENO.
Hope this help!
Edhy Rijo
Users browsing this forum: No registered users and 78 guests
