I'm consistently getting the following message while building patches (as the last line after everything has been built):
Error during build: No compatible base packages found for upgrade package
I've tried adjusting with the Product/Revision/Upgrade codes and version numbers as best as I know how. I'm trying to patch a project built as Web Deployed. I'm using the Trial version to ensure that I can do what I need before I buy--the 7.0 Trial isn't limited, is it?
Any ideas?
Problem building patches
Re: Problem building patches
I had a hard time getting in touch with InstallAware, and when I did they couldn't answer my question, but I was able to solve this one myself through some horrifically painful and repetitive debugging, leading to an astonishingly simple result.
It turns out that this problem can be solved by removing the Setup Password (aka the 256-bit Encryption Key). That's it. With the password I get the error, even in the very simplest scenario; without it everything seems to be fine.
pfennig
pfennig
