Using \"Setup Password\" cause script error
rbs04
Postby rbs04 » Tue Jul 31, 2007 4:59 pm
When I add a Setup Password (for Compress Packages Only)
256-Bit Encryption Key:
The install fails with an error:
Runtime error in setup script:
Line 176: '$
If I remove the password, the install works correctly.
Line 176 is the END REGION for the DEFINE REGION: Process (Un) Installation
There are no customizations to the script other than the Run Program line and that just points to the installed program.
UPDATE:
I changed my password to a short password and the install worked correctly. Is the limit to the length of the password?
Alex_Ronquillo
Postby Alex_Ronquillo » Tue Jul 31, 2007 5:58 pm
What version and edition are you using? Let me know and I will check it up
Alejandro Ronquillo
rbs04
Version
Postby rbs04 » Tue Jul 31, 2007 6:01 pm
Version 7.0 (Build lonepine_rtm.071107)
Here is the password that caused the problem:
"Evaluation AJD1RB14JL63Z"
When I switch to a shorter password it worked.
Alex_Ronquillo
Postby Alex_Ronquillo » Wed Aug 01, 2007 9:35 am
I just checked that password in Studio Admin 7.0 and it did not give me an error. Are you using any other edition?
Alejandro Ronquillo
rbs04
Postby rbs04 » Wed Aug 01, 2007 10:38 am
Nope. That is the only version.
When I step through the debugger, it works fine. But, when I compile it into a single executable and run it, it has the problem.
Alex_Ronquillo
Postby Alex_Ronquillo » Wed Aug 01, 2007 11:07 am
I am really sorry. I cannot recreate your problem and IA doesn't have lenght restriction for passwords. Try creating a new project and use that same password. Maybe your project got corrupted at some point. Please let me know the result.
Alejandro Ronquillo
Users browsing this forum: No registered users and 67 guests
