how modify config files?
baton1234
Post by baton1234 »
How I can modify config files during the installation?
For example, I have a dialog for input of several parameters, what should I do to insert values of this parameters to a config file?
Alex_Ronquillo
Post by Alex_Ronquillo »
For this you can use the "Write to Text File" MSI command. This function writes to a file in the target system either at the beginning or at the end of the file
Alejandro Ronquillo
baton1234
Post by baton1234 »
In this current situation, config files are huge xml documents, and I need only to change several values inside them.
Alex_Ronquillo
Unfortunatelly there is no way to replace certain text in a file. You need to write the whole file content.
Alejandro Ronquillo
Bo Andersen
will this do?
Post by Bo Andersen »
Hey
saw this EditFile plugin in the Plugins section - is that not what you need?
http://www.installaware.com/forums/viewtopic.php?t=81
Bo
Alex_Ronquillo
baton1234,
Bo Andersen is right. That is exactly what you need.
Thank you Bo.
Alejandro Ronquillo
