We are using the new Terminate with Exit Code command to signal if a setup has failed. This works very well.
However it appears that if the setup cannot unpack itself (out of space, etc.) it will return 0 (SUCCESS).
Could you please verify this and change it to return an error code? Thanks!
Return codes
I forced the setup to unpack to a removable media with no free space, in both silence and non-silence ways, and both of the times I get a return code of 1.
Please, try to run the same setup but in non-silence mode, as you will get a message box with a description of the error, and post it here. Thank you.
Users browsing this forum: Google [Bot] and 37 guests
