UPDATE URL
syk
UPDATE URL
Post by syk »
hi,
I need to be able to change the update url
in the client pc after the installation
i tried to change the update sctipt for example
Set Persistent Variable MY_UPDATE_SERVER to
Read Registry Key HKLM\\SOFTWARE\\XXX\\YYY\\\\UPDATE_SERVER into MY_UPDATE_SERVER
Download File $MY_UPDATE_SERVER$ into $SUPPORTDIR$\\updates.ini (get result into variable UPDATE_GET_INI)
and it doesnt work
any suggestion?
i will very hapy if someone will send me some example
THANKS
Gizm0
Post by Gizm0 »
Why it didn't work? What was the error?
Panagiotis Kefalidis
Software Design Team Lead
syk
UPDATE URL - WORKS!
Post by syk »
the problem was maybe because
i was changing the update script and buid a patch
and the changes did not effect the scheduler
when i create new installation project
it works just fine
THANKS
