I downloaded some merge modules for Crystal Reports RDC 11.0 from here:
http://support.businessobjects.com/comm ... es.zip.asp
A few months ago I was able to use the "MSI CAB Decompressor" tool to decompress the merge modules, and then I had better compression.
With InstallAware 2005 Second Edition, that tool seems to have been replaced with the "Setup Decompressor". I'm trying to run it on my merge modules (it accepts *.msm in the open file filter). But it returns immediately with this error:
"File is a merge module, skipping processing: C:\\Files\\cr_rdc_11\\CrystalReports11_RDC_Reportengine.msm"
This seems to imply that the tool is explicity skipping this file because it's a merge module. Do I need to install an older verion of InstallAware to decompress this merge module?
--Troy
Can't decompress a merge module
Users browsing this forum: No registered users and 36 guests
