New Theme: Compact Emerald
Post complete new themes or wizard dialogs here.
sinan
Postby sinan » Thu Dec 09, 2004 6:00 pm
A new theme is available. I've tentatively termed it Compact Emerald. It has been donated by Troy Wolbrink of TntWare.
Thanks Troy for this great mod on the Emerald theme!
You can download the theme at:
http://www.installaware.com/emerald_compact.7zip
(You may use CompreXX or another 7ZIP-compatible tool to extract the archive)
Feel free to send us more of your custom creations - we'll post them here!
MimarSinan
[MS]Mark
Postby [MS]Mark » Fri Dec 10, 2004 12:00 pm
I get an error 'Cannot open file <path>\\ad.bmp. The system cannot find the file specified.' - if I add my own ad.bmp it works otherwise I can't select it for use...
sinan
Postby sinan » Fri Dec 10, 2004 6:52 pm
Yes, if you want to put it into the themes folder along with others, you'll need to make an ad.bmp and text description file :idea:
Return to “New Themes, Dialogs”
Users browsing this forum: No registered users and 4 guests
