Upgrade is not replacing files
rumman
Post by rumman »
Upgrade is not replacing files. The upgrade process is copying the new version of files if no previous version exist in the folder; otherwise the files are not being updated (size and date stamps are same as previous version).
Alex_Ronquillo
Post by Alex_Ronquillo »
That is why is not overwriting the files. IA assumes they are the same and there is no need to rewrite them.
Alejandro Ronquillo
GrandChain
I also see this
Post by GrandChain »
Hi Alex,
I think you've misunderstood. I also see this behaviour (see http://www.installaware.com/forum/viewtopic.php?t=3445).
I can add to this. Not only are sizes and date stamps of the files in the destination folder the same as before I run the installer, so is the version number (and I increment the version number of every executable file before generating a new kit). However, the size, date and version numbers in the kit ARE different - InstallAware just isn't updating the files which already exist.
I have a need for this because I have a family of products which share some common files, and I want those files upgraded to the latest version each time a new kit is installed. According to the documentation, it ought to do what I expect, but it doesn't:
Install Files
Notes
o Windows Installer's default behavior is to overwrite files on the target system if the ones you are copying are newer. ...
I'm using Version 7.0 (Build lonepine_rtm.071107)
Michael - can you make any suggestions? Is this a known bug? Is there a set of switches on a shared DLL which disables this behaviour? I have
[x] Make File Read Only
[x] File is Vital for Installation
[x] Shared DLL File - uninstall only if no other copies in use
All other options are clear.
Cheers,
Ian Brockbank
