Attention InstallAware Gurus,
Thank you in advance for your help.
I am running my installer created in InstallAware on a WinXP Virtual Machine and the installer is trying to download the .NET .7zip file from the internet but it fails with the following error message:
Retry Download? Downloading of installation data from the web has failed. Would you like to try again? On the same dialog I am prompted for proxy information. (Which is strange because I am not using a proxy).
When I close this dialog, another error message appears that says: "Unable to download installation data from the web"
My internet connection works as you would expect. When I type in the URL of the .7zip file that it is trying to download in internet explorer I can download the .7zip file successfully without errors.
The curious thing with this issue is that my installer created in InstallAware works fine in Windows 2000. When I run my installer on a Windows 2000 Virtual Machine everything works fine, the .NET .7zip file is downloaded from the internet and installed successfully. It is just WinXP that has a problem.
The Firewall is turned off on my WinXP Virtual Machine.
Any ideas why this is happening?
Dencolp
