I'm experiencing a strange problem with installation of SQL Server Express.
Actually, there are two problems.
1. SSE package creates folder ~sqltmp or ~sqltmp0 if one already exists. Problem appears when both folders exist, then installation doesn't work. I figured out that these folders act key role in this case: after deleting these folders installation goes fine.
BUT... I can't see instruction that allows to remove folder automatically.
Question: How do you usually manage this problem?
2. The bigger problem shows up when I try to cancel SSE installation process. When I click 'Cancel' the message about it appears, but the progress window (not in modal mode) doesn't dissapear. Installation process seems to crash
[DEFINE WEB MEDIA Microsoft SQL Server 2005 Express]
Get Component Microsoft SQL Server 2005 Express Selection State into Variable SELECTED
Display Dialog: progressprereq, use as progress dialog (non-modal)
Include Script: checksql2005
if Variable SQL2005 Equals TRUE
GoTo Label: sql_serversetup
else
Include Script: setupsql2005
Hide Dialog
In original setupsql2005 I changed only parameters password and instance name.
Question: How to solve that problem?
