RuntimeExecute, Windowhandle = 0
rcaspers
Postby rcaspers » Fri Sep 12, 2008 6:58 am
Hi there, I made myself a plugin, But when the runtimeexecute function is called the Window parameter is 0, Is there a way to work arround this?
Postby CandiceJones » Fri Sep 12, 2008 3:33 pm
An active window might not be showing then? Also try in a built setup run outside the IDE for more accurate results.
rcaspers
Postby rcaspers » Sat Sep 13, 2008 5:00 am
When i run the setup both in- en outside the IDE there is an active setup window. I used a messagebox to diaplay the window handle and in both cases it is 0.
rcaspers
Postby rcaspers » Wed Sep 17, 2008 12:04 pm
Also inside my project, when i display the WINDOWHANDLE variable with a messagbox it shows me 0
cmwallace
Postby cmwallace » Tue Aug 04, 2009 3:32 pm
I have also found the $WINDOWHANDLE$ value to be 0. This is a problem when attempting to call the ShowWindow API using Call DLL Function in an effort to minimize the installer. That, and I don't know what to pass the parameter as. An HWND is a struct, but having a $WINDOWHANDLE$ variable would indicate that perhaps it is supposed to be passed as a pointer to double word?
rcaspers
alternative way to find the window handle
Postby rcaspers » Wed Aug 05, 2009 12:43 pm
If found an alernative
FindWindow('TPoolTemplate','complete caption caption of the window ');
replace ''complete caption caption of the window ' by the caption
probably something like: $project name$ + ' - InstallAware Wizard'
Greetings
René Caspers
Postby CandiceJones » Wed Aug 05, 2009 1:05 pm
I believe this is fixed in InstallAware 9.
rcaspers
Yes it is
Postby rcaspers » Tue Dec 15, 2009 2:03 pm
I noticed that the problem is solved, thanks
Users browsing this forum: No registered users and 105 guests
